TwinTurbo.NET: Nissan 300ZX forum - I wouldn't ever grind an OEM crank...
ZinnZ32
on April 03, 2013 at 1:52 PM
looks like it'd be fine after a grind and oversize bearings. (n/m)
posted by nemo1080 (Iowa)
on April 03, 2013 at 12:47 PM
Learned that the hard way two years ago. They are just not as strong without the nitride layer
__________
Version 3.01
Curious if a crank is salvageable
BlackholeZ
11:39:24 04/02/13
The way I tell
Cjw3
15:45:46 04/02/13
If you have the crank ground, it will need to be re-nitrided (n/m)
ttsmokin
16:48:57 04/02/13
and at that point I would just find another crank. (n/m)
BlackholeZ
17:00:11 04/02/13
It's really hard to detect anything
BlackholeZ
19:11:46 04/02/13
+1 would any of you engine builders out there
Zvil (FL)
19:32:32 04/02/13
Re: Curious if a crank is salvageable
Tech@EPR
19:55:39 04/02/13
Is polishing considered reconditioning?
BlackholeZ
21:04:24 04/02/13
Re: Is polishing considered reconditioning?
Tech@EPR
17:28:07 04/03/13
If it needs a grind, just go with a good condition original
ZinnZ32
12:19:03 04/03/13
Not going for big power, want reliable, and smooth
BlackholeZ
04:00:52 04/04/13
nemo1080 (Iowa)
12:47:41 04/03/13
I wouldn't ever grind an OEM crank... -
ZinnZ32
13:52:23 04/03/13
Re: I wouldn't ever grind an OEM crank...
Tech@EPR
17:29:44 04/03/13
I think Zinn was meaning not to grind without re-nitriding
ttsmokin
19:59:05 04/03/13
Is it even worth it though to go through all that?
BlackholeZ
04:04:10 04/04/13
+1 Pretty sure getting one Nitrided isn't easy or cheap... (n/m)
ZinnZ32
12:37:47 04/04/13
Re: +1 Pretty sure getting one Nitrided isn't easy or cheap...
Tech@EPR
13:44:39 04/04/13
Looking around it's a couple hundred bucks. (n/m)
BlackholeZ
01:43:50 04/05/13
